Print at Oct 16, 2026, 8:13:22 PM
Posted by Puybaret at Mar 16, 2018, 1:57:15 AM
Re: Sweet Home 3D files format specifications like extension sh3d versus zip , jar format
SH3D and JAR files are just ZIP files, compressed or not.
The main entry of a SH3D file is named Home and contains a Java serialization of the Home class instance that describes the designed home. In old versions, this entry had to be the first one in a SH3D file.
From version 5.3, there’s also a copy of the designed home in a new entry named Home.xml which respects SweetHome3D.dtd. This XML entry was added to be able to read and save SH3D files in JavaScript and other environments. This entry is read in priority when a SH3D file is opened and the Home is stilll saved for compatibility with previous versions of Sweet Home 3D.
During a few more versions, I foresee to save Home and Home.xml in a SH3D file even if they contain similar data. This is to ensure a smooth transition with future files where Home entry won’t be saved anymore. The extension of these future files will be .sh3x which is already associated with Sweet Home 3D application since version 5.3 too. Future versions will also be able to read SH3D files without a Home.xml entry as long as Java deserialization will be possible with Home entry.
The other entries of a SH3D file are the optional entry named ContentDigests (added in version 4.4) which contains digests of home data to help repair a corrupted SH3D file, and numbered entries that contain images and 3D models used by a home.
