Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: levels, floor thickness and wall heights » » » » Post: Re: levels, floor thickness and wall heights |
Print at Sep 25, 2026, 12:16:42 PM |
| Posted by Puybaret at Mar 23, 2018, 10:37:54 AM |
Re: levels, floor thickness and wall heights The elevation of a level is the height at which a floor of a level appears and where objects are placed. The Compute walls option tries its best but as walls are not "glued" to rooms in the program, it can't work perfectly. Keep in mind that you can change walls directly with their modification dialog box, and that you can also split a wall with the Plan > Split wall menu item. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 25, 2026, 12:16:42 PM |
