Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Is Sunflow limited in Sweet Home 3D? » » » » Post: Re: Is Sunflow limited in Sweet Home 3D? |
Print at Sep 24, 2026, 12:50:08 AM |
| Posted by enkonyito at May 1, 2018, 4:37:55 AM |
Re: Is Sunflow limited in Sweet Home 3D? Yes I had tried but not as it should because I had not understood that the position of the light source is a percentage of the width, depth and height. I applied this methodology to the vertices of my object and it works. Since taking vertices into account is manual, only one shape is possible. By generating a transparent or invisible 3D shape, the light panel is rendered opaque when it is turned on. For the wired 3D shape, I realized that the object had to be already in the .obj file. The TriangleMeshLightWithNoRepresentation class does not cause the expected effect. ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 24, 2026, 12:50:08 AM |
