Print at Sep 25, 2026, 3:46:12 PM
Posted by dorin at May 3, 2018, 1:39:55 PM
Re: Grouping elements
It's about the order to draw it.(Look in the furniture list)
The order of insert is: lower cabinet, ceramic hob and upper cabinet.
After grouping will look OK in both (2D & 3D).
If You don't want to redraw all, You can use the cat and paste in same place until realize the needed order.
The same are happen when You insert table before chairs and You want them partially under table.
