Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to create a down light embedded in the ceiling » » » » Post: Re: How to create a down light embedded in the ceiling |
Print at Sep 23, 2026, 11:23:00 PM |
| Posted by enkonyito at May 6, 2018, 12:12:26 AM |
Re: How to create a down light embedded in the ceiling okh, in relation to your interrogation, Last attempt of the day, a directional downlight with here are some details.<light catalogId='okh#spot_dir_cut' name='Spot_focus_dir' creator='okh' model='1/downlight_directional.obj' icon='0' x='69.5' y='290.55923' width='20.0' depth='10.0' height='10.0' modelSize='14936' staircaseCutOutShape='m .52,0.5 a .23,.46 0,0,1 .46,0 a .23,.46 0,0,1 -.46,0 z' power='0.4'>By default, SH3D uses the SphereLight type to render lights with the Sunflow rendering engine. As you already know, just add these properties for an object to be considered a light by SH3D. The LIGHT_SOURCE_DIAMETER property is optional. If it is not present, a default value is used for the calculation of the radius of the sphere as for the lights created before SH3D-3.0. When it is present, its value is taken into account and makes it possible to obtain soft shadows when the size of the light is enlarged. Regarding the position of the light source in the Home.xml file, the values represent a percentage of the width-depth-height of the object containing it. In your example, <lightSource x='0.25' y='0.5' z='0.7' color='00BB9854' diameter='0.125'/>lightSourceX#n=0.25*lightWidthMy trick to properly position the light sources of a light is to match the lower left corner of the object with the origin (0, 0) of the Sweet Home 3D plan knowing that the Y axis is reversed. modelXplan = modelWidth / 2modelElevationProperties = modelElevationPlanHoping to have been pretty clear. ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 23, 2026, 11:23:00 PM |
