Print at Sep 27, 2026, 7:04:00 PM
Posted by Puybaret at Aug 28, 2008, 12:00:00 PM
Re: Bibliothèque pour multipostes
An English user requested almost the same thing :
> I've been using Sweet Home 3d for the last 2 months, now I have bougth
> a new laptop, how can I install the 3D models paquets?,
> I need them to work with my old projects in the new computer.
Here's the translation in English of my message posted at http://www.sweethome3d.eu/support/forum/viewthread_thread,966#3856
- To copy imported furniture between Windows computers, you have to copy files contained in the directory "C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D" of the old computer to the new computer (replace "user" by your Windows login).
You also have to copy registry keys contained in the registry folder named "HKEY_CURRENT_USER\Software\JavaSoft\Prefs\com\eteks\sweethome3d\io" : launch registry editor "regedit" on the old computer, select folder "HKEY_CURRENT_USER\Software\JavaSoft\Prefs\com\eteks\sweethome3d\io" in the tree of the registry editor and choose menu "item File > Export...".
Then, launch registry editor on the new computer and import the exported file with the menu item "File > Import...".
- To copy imported furniture between Linux computers, you have to copy files contained in the directories ".java/.userPrefs" and ".eteks" found in the user directory of the old computer to the same directories on the new computer.
- To copy imported furniture between Mac OS X computers, you have to copy the file "Library/Preferences/com.eteks.sweethome3d.plist" and the folder "Library/Application Support/eTeks/Sweet Home 3D" found in the user directory of the old computer to the same directories on the new computer.
