Print at Sep 25, 2026, 6:55:20 AM
Posted by okh at May 15, 2018, 7:53:40 AM
Re: Objects with texture
The easiest, I guess, is not to move anything before using Import Furniture in SH3D. That is, import them from where you originally saved the DAE or OBJ files...
If you need to move them,
OBJ requires:
xxx.obj (the .obj file itself)
xxx.mtl (specifies the materials used)
xyz.jpg / xzz.png (texture files referenced in the .mtl file)
DAE requires:
xxx.dae (the .dae file)
and usually a directory with the same name (xxx or whatever) with texture files (.jpg/.png/.gif)
So if you go to your export directory and select the above and move them together, it should work.
