Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create slab or room with angled edges » » » » Post: Re: Create slab or room with angled edges |
Print at Sep 26, 2026, 6:58:26 AM |
| Posted by Puybaret at May 18, 2018, 11:41:10 PM |
Re: Create slab or room with angled edges Polylines are only used to annotate the plan and have no effect in the 3D view. You should rather draw rooms but walls around a room are always vertical. As a workaround, you may use thin boxes and rotate them horizontally to create such walls but you may find this too tedious if all the walls must be handled this way. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 6:58:26 AM |
