Print at Sep 24, 2026, 7:19:03 AM
Posted by pencilart at Sep 8, 2008, 7:09:00 PM
Re: Different floor textures in different roo
I thought of a bit of a work around:
Use the cube that you provided (the box in the Miscellaneous category) and just flatten it. Then apply a different color for each room that you've put it in. However, it would be a problem if the room is not square or has a "bay" area (sticks out with the walls at an angle other than 90ยบ.)
