Print at Oct 12, 2026, 8:08:11 AM
Posted by Ceciliabr at Jun 3, 2018, 6:18:07 PM
Here are some notes I have made over a period of time.
1) OBJECT SIZE
I will suggest an option to use a modifier key to restrict object resizing to one direction only.
Holding “SHIFT” works perfectly as it is. Maybe holding “ALT” or “CTRL” to restrict “Y” or “X”-direction could be possible?
2) PIVOT
It would be helpful to be able to user-define the pivot that an object will rotate around. Placement at one of four selectable corners, and one of four selectable mid-sides.
3) GUIDELINES
I miss having user defined guidelines, preferably with a snap-to function.
4) ALIGN
Options should include “Align at centre”.
5) BASE PLAN
a) An option under the Select-menu: “Select from base plan” – an option that temporarily disconnects the selected object from the Base Plan until it’s modified, and then reconnects it when closing the Modify-window. (Makes a locked object selectable for modifying without unlocking the base plan)
b) An option to lock any specific objects select-ability in the plan, regardless of whether the base plan is locked or not. The object will then be invisible in the plan, but still selectable from the list.
c) The compass should not be part of the Base Plan.
6) LEVELS
Is it possible to include “Make only this level viewable” ( hide all other levels), and “Make all levels viewable”?
7) MODIFY
Can we have an option under “Modify” to auto-apply the same texture to all – like to all six sides of a cube (box)?
8) SKY
Is it possible to enable sky texture rotation?
9) CAMERA
The virtual visitor should have handles making it possible to access them at any zoom-level.
10) ZOOM
Zoom in / out ( CMD + / -) should hold the selected object in the centre of the plan.
11) PROJECT
It would be nice to have an option to merge projects and to export / import levels between projects
And while I’m at it; the video rendering tool formats are a bit behind times. The 2.40 - format would be nice to have :
4K Scope 2.39:1 (referred to as 2.40)  /  4096x1728 – 24/25 fs
HD 1080P Blu-Ray (2.40:1)   1920x800 – 24/25 fs
HD 720P 2.39:1 (referred to as 2.40)  /  1280x536 24/25 fs
