Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: SH3D on Windows 10 on ARM works using DirectX » » » » Post: Re: SH3D on Windows 10 on ARM works using DirectX |
Print at Aug 25, 2026, 9:11:07 AM |
| Posted by Puybaret at Jun 8, 2018, 10:37:08 PM |
Re: SH3D on Windows 10 on ARM works using DirectX Thanks for your tests The DirectX version of Java 3D requires to run Sweet Home 3D in 32 bit. Isn't it a problem under ARM64? Did you run Sweet Home 3D with its JAR Executable version or from the installer running with /j3d.version=1.5.2 /os.arch=x86 flags and a SweetHome3D.l4j.ini file containing DirectX properties placed in Sweet Home 3D installation folder? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 25, 2026, 9:11:07 AM |
