Print at Sep 24, 2026, 7:57:36 AM
Posted by Xiste at Jul 2, 2018, 10:41:54 AM
Re: Adding a subfloor to an existing single story design
Remember to check the floor thickness when you elevate a ground level.
Sh3d automatically adds floor thickness, limited to the height set in your preferences, so if you elevate a ground level with less of equal to the floor thickness in your preferences, your walls will just get an increased height and still remain standing on the ground.
If you want your walls to stand on top of your subfloor, you must set the floor thickness to a minimum. 0 cm is not possible, but 0.1 cm works.
Xiste
