Print at Sep 23, 2026, 11:51:43 PM
Posted by UbuntuBirdy at Jul 8, 2018, 11:52:30 PM
Re: Holes in the ground
You are right, I do not get it. Still do not, I am afraid. But I am curious, maybe you could post a model?
It's not your fault, it seems I'm not able to describe my problem properly...
I understand your solution, but in my opinion, this is only a workaround, and sorry, I'm a perfectionist, and workarounds are only temporary solutions and for me not aceptable. That does not mean they are not good, it's my crazy compulsion to have everything perfect... And in my opinion, a software like sh3d can only get better, if a workaround is not a solution forever.
Ok, you asked for a model: Luxemotor Hull
This is a hull from a old inland cargo vessel.
If I have to create a cutout path, I have to do one for every mm in height because the ships has a different draft for different loads. Ergo, your solution is not the right solution.
And now I go back to the Groups. How can I apply your solution to groups? As you can see in my first post, they cut holes where nothing is.
Believe me, I am very grateful for your help, but in my opinion that is not a solution to my problem.
