Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 6.0 » » » » Post: Re: Sweet Home 3D 6.0 |
Print at Sep 30, 2026, 11:17:07 AM |
| Posted by enkonyito at Jul 9, 2018, 4:57:11 PM |
Re: Sweet Home 3D 6.0 @Puybaret The issue on the latest is that the light sources associated with the 3D model won't rotate themselves, but I have an idea to make it work: if a light source intersects with a rotated part, it sounds logical to make it rotate too. If it works it would be nice. Otherwise, the number of articulated lights is limited at the moment.About your test on the Slider window, this shouldn't happen simply because the windows of this model aren't supposed to go beyond the frame! I realized this by observing the object in detail and comparing with reality. Would it be possible for the opening to be stopped by the frame?For a pocket door , we can find a trick to integrate it into the wall. ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 30, 2026, 11:17:07 AM |
