Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Holes in the ground » » » » Post: Re: Holes in the ground |
Print at Sep 26, 2026, 1:48:01 PM |
| Posted by UbuntuBirdy at Jul 9, 2018, 10:29:01 PM |
Re: Holes in the ground But for a house boat, I think there sort of is an answer to your challenge as different displacements are standardised. Btw, the standard displacements are a little bit different for a houseboat navigating the european waterways... on one way easier... on an other way much more complicated... The only thing that counts is: as less as possible into the water (minimal draft) and, what makes it complicated, as less as possible out of the water (clearance under the low bridges). And this is the only reason why the waterline could change also for a houseboat - there are ballast tanks - full for passing a low bridge (e. g. capestang), and empty if the canal is very shallow (e. g. nivernais) ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Sep 26, 2026, 1:48:01 PM |
