Print at Oct 16, 2026, 7:40:47 AM
Posted by Puybaret at Jul 10, 2018, 12:09:19 AM
Re: Variable names on dimensions
There’s no variable but if you want set the same size to a group of objects, select them (with a selection rectangle or thenshift key to add an object to current selection), choose Furniture > Modify menu item and set the value(s) you want in the modification dialog box.
