Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Holes in the ground » » » » Post: Re: Holes in the ground |
Print at Sep 26, 2026, 9:43:24 AM |
| Posted by UbuntuBirdy at Jul 10, 2018, 2:58:53 PM |
Re: Holes in the ground .. in my opinion, this is only a workaround, and sorry, I'm a perfectionist, and workarounds are only temporary solutions and for me not acceptable. So, this is where I disagree. I do not see manually adding SVG for advanced models as a workaround. Quite the contrary. For models with complicated shapes, it will be better if SH3D does not make assumptions about how to cut / intersect with other surfaces. Letting the model maker (or the user) is - I think - much more professional, or perfectionist if you like.After a long night of studying my possibilities with sh3d, FreeCAD and Inkscape I could not resist to give your solution a try, and now I have to say yes, you are right, this is a solution. It's absolutely not as much effort as I thought it is, but it's even not the simple solution sh3d should offer for most of the end-users. Group Cutout But as you can see in the picture, the groups still cut big holes. Is there a possibility to define groups do not cut anything? BTW, the staircaseCutOutShape-entry for the hull is exact 66662 rows long... ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Sep 26, 2026, 9:43:24 AM |
