Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Showcase your glassblocks » » » » Post: Re: Showcase your glassblocks |
Print at Aug 30, 2026, 7:10:42 AM |
| Posted by AdeleAlli at Jul 26, 2018, 4:30:28 PM |
Re: Showcase your glassblocks If you want to render in Silky mode, maybe you can try reducing the shininess of the texture for the object (faucet). I also find that rendering at higher resolution helps. If you have the time and patience, you can try rendering at 3000-5000dpi. It may take 6-7 hours but you can let the computer do the job while you sleep. What is the Silky mode and where I can change it? Is it in the script of sh3d (under linux)? Thank you, I usually render at 3000 x "something" (I use the auto-adapt option) pixels. Usually it takes 20/30 minutes, more or less, with an octa core processor. How I can change the dpi resolution of the rendering? |
Current timezone is GMT Aug 30, 2026, 7:10:42 AM |
