Print at Sep 24, 2026, 6:20:33 PM
Posted by AdeleAlli at Aug 12, 2018, 7:27:03 PM
Re: Mini Cottage
I personally like spiral staircases. In my opinion they are the best compromise to use as less space as possible and to have a most comfortable staircase.
Hi, thank you for the suggestion.
I tried to use a spiral staircase. The result is that there is more space now, but I have two problems:
- how to close the space left by the staircase at the second floor (I used 50 cm walls to do it, but I don't like it very much);
- the staircases with handrails that are present in sh3d were too big, and the only one I was able to use is that without handrails, but in a real solution I think that I'll prefer to use handrails.
Here are some renderings:
Ground floor with the fireplace and the staircase
Ground floor with the kitchen corner and the staircase
First floor with the 50cm walls closing the staircase, and the living room area with a desk and a pc (it is a must for me even in a cottage :D )
A view of the ground floor plan to see how much space the staircases occupy now
I know that it is not the right place to ask it, but does someone know how to use staircase models downloaded from other sites? I tried to do that but the staircases that are not sh3d models already present does not leave the space upstairs, so it requires more effort to use them, but in this case I found smaller models that in my opinion where more appropriate for the design of this cottage.
Thanks
