Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can't Modify walls » » » » Post: Re: Can't Modify walls |
Print at Oct 2, 2026, 2:34:11 AM |
| Posted by Puybaret at Aug 27, 2018, 5:32:40 PM |
Re: Can't Modify walls Thanks for your file. I fixed it and sent it back to you. The error was about levels management as you noticed it. Even if you removed all levels, some objects still had a wrong level information, preventing to select them. I'm going to try to reproduce the issue to fix it... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 2:34:11 AM |
