Print at Sep 23, 2026, 6:24:42 PM
Posted by Puybaret at Aug 31, 2018, 12:59:25 PM
Re: RULES FOR DEFINING 3D STRUCTURE
As with any program, you can program all the controls you want.
But the good question is when and how should be displayed the controls you want to add. If you display a popup as soon as your conditions are not verified, this may interrupt user's input. If you want to add a menu item that will check your conditions, you might not be able to force the user to modify his design.
Maybe you could try to program a plug-in for this?
