Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How create a balcony .... » » » » Post: Re: How create a balcony .... |
Print at Sep 29, 2026, 7:28:28 PM |
| Posted by Lilia1996 at Aug 31, 2018, 2:59:45 PM |
Re: How create a balcony .... Let's build a balcony in Sweet Home 3D We will deal with the arrangement of the finished house a little later, and now I suggest that you make a balcony. You may need to work with hardware that is different from the standard kit. How to create a balcony Before choosing the right color. Now go to the section "Exteriors", where you want to find the pillars of the porch. Their standard sizes are suitable only for the veranda. That's why you need to make changes that will allow you to arrange columns from the ground floor to the area of use of the future balcony. Their standard sizes are suitable only for the veranda. That's why you need to make changes that will allow you to arrange columns from the ground floor to the area of use of the future balcony. Next, we'll work on the railing. We go to the section called "Miscellaneous", where the "Fencing" parameter is located. Choose from the list what we like most. We will establish a connection around the perimeter fence. To make everything look as clear as possible, the designer sketched with marble not only the railing, but also the floors with columns. We are close to the final stage of the work. On the balcony you can place a special lounger or coffee table. Fantasize a little. Set on the table a fruit bowl and a couple of glasses of wine. For the sake of decorating the balcony you can get flower boxes, which should be hung from the outside. Flowers can be quite diverse, to your taste. Done! Now you can render and admire your virtual creation. During my work in Tsymbals Designs. - I was surfing on the Internet and was found an interesting article about that topic. |
Current timezone is GMT Sep 29, 2026, 7:28:28 PM |
