Print at Oct 5, 2026, 11:27:36 AM
Posted by Puybaret at Sep 2, 2018, 1:52:23 PM
Re: How to provide floor plan parameters in a file
The simplest way is probably to use a .sh3d extension for your file instead .xml, so the open file dialog will let you select it. You can also use a command line tu run Sweet Home 3D application followed by -open parameter and the file you want:
path/to/SweetHome3D.exe -open path/to/project.sh3d
But caution, if you will save, the generated SH3D file will be at default file format, i.e. a zip file containing a Home.xml entry and other entries for images and 3D models.
