Print at Sep 24, 2026, 10:43:51 AM
Posted by pencilart at Mar 9, 2009, 3:34:00 PM
Re: mtl problem
Yes, as Emmanuel said, name your texture/material from within AOI and then re-export it.
(Just in case you need this):
From the top menu bar, go to Scene > Textures and when the dialog box pops up, click on the texture you want to change and click Edit. Then you can name it.
When you re-export it, the name of the texture should now be there and the file should work.
