Print at Sep 23, 2026, 7:39:20 PM
Posted by Puybaret at Mar 20, 2009, 7:44:00 PM
Re: Cannot compile and run SweetHome 3D from
Under Windows, did you try to "open Run Dialog in Eclipse,
select the Arguments tab of the target application, and add to the VM arguments
text field the option -Djava.ext.dirs=lib;lib/windows" as mentioned in the README.TXT file available at project root and at http://sweethome3d.cvs.sourceforge.net/viewvc.../README.TXT?revision=1.15 ?
Under Ubuntu, I guess you used Java 1.4 and not Java 1.5 compiler from the errors you reported ( see the mention "since 1.5" at http://java.sun.com/j2se/1.5.0/docs/api/javax...ane.html#W3C_LENGTH_UNITS ).
