Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Objects furnure disappeared on project » » » » Post: Re: Objects furnure disappeared on project |
Print at Sep 24, 2026, 10:43:46 AM |
| Posted by Puybaret at Mar 22, 2009, 9:04:00 AM |
Re: Objects furnure disappeared on project Sweet Home 3D must run out of memory, because the white box is used only during the loading of the 3D model (I would be nice that Sweet Home 3D warns you but I didn't program that yet). Save your home and relaunch Sweet Home 3D. If the white boxes still appear after you open your home, you use too much furniture, but there's still a solution to increase the memory granted to Sweet Home 3D. Download SweetHome3D-xxx.jar at https://sourceforge.net/project/showfiles.php...568&package_id=245525 , and run the command: java -Xmx1024m -jar /path/to/SweetHome3D-xxx.jar where "1024" is the maximum amount of memory in MB the program will take and "/path/to/SweetHome3D-xxx.jar" the path of the "SweetHome3D-xxx.jar" file you downloaded. For you information, this value is 384 MB in version 1.7. This is not very user friendly, but it's an immediate workaround that works. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 10:43:46 AM |
