Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: The format of the chosen model isn't supported. Please chose an other model. » » » » Post: Re: The format of the chosen model isn't supported. Please chose an other model. |
Print at Sep 26, 2026, 8:48:20 PM |
| Posted by Ceciliabr at Sep 10, 2018, 10:18:18 AM |
Re: The format of the chosen model isn't supported. Please chose an other model. This sounds promising, what do you do to fix this error? First try to rename the .mtl-file so SH3D don't see it. If you can import the model (it will be all grey) without the .mtl-file, then you have at least located the problem. We don't know yet if I'm right – but assuming I am: My best advice is to open the .mtl-file of a model that you know is working, and then compare it with the non-working. You might spot the error – or you might not. 3D builder is likely to produce the same errors again. Then you have to learn how to wash your mtl-files, or you will be stuck. Lots of luck! Cec |
Current timezone is GMT Sep 26, 2026, 8:48:20 PM |
