Print at Sep 26, 2026, 8:48:54 PM
Posted by Grant_Edwards at Apr 5, 2009, 7:12:00 PM
Re: Can't get dimension lines to work
>Yes, I think you missed or forgot the first part of the user's
>guide at http://www.sweethome3d.eu/userGuide.html#importingHomeBlueprint
>and the first part of the video tutorial at http://www.sweethome3d.eu/documentation.html#videoTutorial :
>importing the blue print of your home to draw walls upon it.
I don't _have_ a blueprint. If I had a bluprint, I'd just use
that. I wouldn't need to draw a floorplan.
I've managed to get a partial floorplan done -- it's not easy,
but if you lay out the dimension lines first, and then eyball
the wall placements to get the dimensions right, you can get
something approximate. Things don't ever line up exactly.
There's no gravity/magnetism, so wall positions won't "snap" to
the dimension lines (or each other). Other objects (cabinets,
bathtubs, etc.) won't snap to walls or dimension lines either.
It's probably close enough, but when you print it out there all
lots of small gaps and overlaps that shouldn't be there.
Now I'm stuck trying to figure out how to print to a large
paper-size. There's a "custom" selection, but it doesn't seem
to do anything.
[It' would be awfully nice if there was a way to turn off of
the 3D stuff. The program is pretty sluggish, and I assume
it's the 3D stuff that's slowing it down.]
Unfortunately, I think it's time to install Windows and go back
to the program I used to use. :(
I hate Windows, but at least I can do a large-format printing,
walls are all connected to each other, and dimension lines are
associated with the things they're measuring. I also like the
use of standard floorplan symbols instead of the white
bounding-box with the rendered picutre.
Grant
