Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: NegativeAllow the elevation of the object to be negative! » » » » Post: Re: NegativeAllow the elevation of the object to be negative! |
Print at Sep 26, 2026, 11:41:21 PM |
| Posted by YGYL at Sep 21, 2018, 3:04:53 PM |
Re: NegativeAllow the elevation of the object to be negative! You can always create a "middle" level called for example (railing or floor-divider) whose have a lower elevation than the upper floor, so you can add things there at your desired elevation Adding more unnecessary floors will make things more complicated and less convenient to understand.Beginners may be totally confused. But if the height of the object can be negative. It's all simple and efficient. |
Current timezone is GMT Sep 26, 2026, 11:41:21 PM |
