Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 6.0 » » » » Post: Re: Sweet Home 3D 6.0 |
Print at Oct 4, 2026, 8:08:54 AM |
| Posted by Puybaret at Sep 23, 2018, 2:09:40 PM |
Re: Sweet Home 3D 6.0 Cec, in the macOS version based on Java 8, edit the SweetHome3D.cfg file found in the Contents/Java subfolder of Sweet Home 3D application and set the maximum memory in a line -Xmx set after the line [JVMUserOptions], writing for example -Xmx6g for 6 GB. If the SweetHome3D.cfg file is protected, run a command like sudo nano /Applications/Sweet\ Home\ 3D.app/Contents/Java/SweetHome3D.cfg---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 8:08:54 AM |
