Print at Sep 26, 2026, 1:48:57 PM
Posted by Puybaret at Apr 19, 2009, 5:44:00 PM
Re: 'VectorWorks' output not rendered correct
If you tried to import your model at 3DS format, your problem is probably due to a bug in 3DS library, as explained in http://www.sweethome3d.eu/faq.html#3DModelsImport
Try to import it at OBJ format. In case you need it, you can use Blender to convert a 3DS model to OBJ format.
