Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Before 6.0 » » » » Post: Re: Before 6.1 |
Print at Sep 24, 2026, 11:35:51 PM |
| Posted by TalonKarrde at Oct 8, 2018, 1:10:58 PM |
Re: Before 6.1 Hello Together, I'm quite new to SH3D, and with the exception from one feature, it's in my opionen the perfect solution to get a draft from your home - A "Profil View" with measurements. My Goal is to get an offer from different construction companies for my House, but therefore I not only need the ground plan/view with the dimensions/measurements, they also request a so called "Profile View" from he building. Up to now I wasn't able to get this out of the default view and wasn't able to find a tip or an other valid workaround. Thus I would higly recommend a this feature. As far as my java knowledge reach, there is already a method to get every "Wall-Object" on a line. So it would be sufficient that you can define a point A and a point B in the "Home Plan" View. The line (or more like a slice thats generated) collects the different informations of the objects it's meeting and displays it. After that one can add the measurements via the "usual" measurement tool. I even wouldn't mind if the Profil View has to be updated manually. If anyone needs further explanation or if the description is to short, just let me know, I will gladly write more. Thank you all in advanced and also lots of thanks for the already great solution! Jan |
Current timezone is GMT Sep 24, 2026, 11:35:51 PM |
