Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 6.0 » » » » Post: Re: Sweet Home 3D 6.0 |
Print at Sep 30, 2026, 9:54:00 PM |
| Posted by UbuntuBirdy at Oct 9, 2018, 1:39:09 PM |
Re: Sweet Home 3D 6.0 Could you send me a demo file with textures that don't behave as in version 5.7? Found a temp-file that you can look at. It's too big for my mail server, but here it is: PCTY_LVLS.sh3d Look at the outer wall texture. The height is set to 900 cm. I have to open the modify walls window, find the texture ( cement_13) and open the modify texture window, and then, without modifying anything, just click ok – not cancel. Close the modifiers and the texture will display correct. Cec EDIT: Forgot: First load texture cement_13.jpg and set height to 365.9 cm. Do this prior to opening the .sh3d-file. Cec On Ubuntu 18.04 I have to reselect the texture of both sides of the wall before the texture will display correct. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Sep 30, 2026, 9:54:00 PM |
