Print at Sep 27, 2026, 7:33:58 AM
Posted by YGYL at Oct 13, 2018, 12:14:21 PM
Re: Woods and grass
My thoughts on Pre-segmented dynamic object system's custom user interface
Allow advanced user defined material library
It also provides ordinary users to define him in software.
This will be a great pleasure for software. I hope users can create some interesting things when using software. So there is no need for too many restrictions.
The whole process is reflected in a Script form. The software executes some items on the table down.
If set correctly, those cases in my front post will be reached.
After execution, a new object is generated in the object bar. Drag and modify this new object to automatically create complex objects.
Script form
Type is the most important column.Determines the function of this script.Other columns are his parameters.
left
Middle (simple)
Pattern 1
Pattern 2
Pattern 3
Right
corner
Inner corner
Outer corner
Random placement (square)
Random layout (circle)
Several choices 1 (Book)
Intermittent repetition
blank
