Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: /lib/ld-linux.so.2: bad ELF interpreter » » » » Post: Re: /lib/ld-linux.so.2: bad ELF interpreter |
Print at Sep 27, 2026, 10:43:31 AM |
| Posted by Puybaret at May 26, 2009, 8:48:00 PM |
Re: /lib/ld-linux.so.2: bad ELF interpreter You can run Sweet Home 3D on a 64 bit JRE with Java Web Start and the JNLP file http://www.sweethome3d.eu/SweetHome3D.64bits.jnlp Note : this JNLP file will be available until the next version of Sweet Home 3D that will be released in the coming days. Then the default JNLP file of Sweet Home 3D will incorporate changes for 64 bits. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 10:43:31 AM |
