Print at Oct 11, 2026, 4:15:16 AM
Posted by UbuntuBirdy at Oct 21, 2018, 4:18:47 PM
Re: massive color-difference
I noticed that the table and chairs, which are textured, are more similar between the two render modes.
More as a test or possible workaround (if it works) than a definitive solution, could you make a little bitmap containing only the plain color that you want to use and then use it as a texture for the material? I wonder if it will be processed the same way... thinking
Easy and simple idea - and it totally works!!!
For me this is a workaround and I can live with this as a solution, but I'm still wondering what's the issue with the colour...
