Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Imported objects are transparent! » » » » Post: Re: Imported objects are transparent! |
Print at Sep 26, 2026, 6:56:31 AM |
| Posted by Puybaret at Jun 9, 2009, 11:19:00 PM |
Re: Imported objects are transparent! > How can I make them visible? The easiest way with Sweet Home 3D would be to: - import the model 3D file in an empty home - export it to OBJ format with "3D view > Export to OBJ format..." - edit the MTL file generated along with OBJ file with a text editor - change the transparency line that starts with "d xxx" to "d 1" - save MTL file - import the exported OBJ file ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 6:56:31 AM |
