Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome3d shut down after some seconds » » » » Post: SweetHome3d shut down after some seconds |
Print at Sep 27, 2026, 8:56:50 AM |
| Posted by C_Valanc at Jun 11, 2009, 12:44:00 PM |
SweetHome3d shut down after some seconds When I start "SweetHome3D.exe". The SweetHome3D window is displayed some seconds and then is closed. Same problem with "SweetHome3D.jnlp". But, strangely for me, if I use SweetHome3D-2.0.jar, the software is entirely usable ! First lines of Error files "hs_err_pidxxxx.log" : - With "SweetHome3D.exe", : # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6941084a, pid=4088, tid=4016 # # JRE version: 6.0_14-b08 # Java VM: Java HotSpot(TM) Client VM (14.0-b16 mixed mode windows-x86 ) # Problematic frame: # C [atioglxx.dll+0x41084a] # - With "SweetHome3D.jnlp" : # # An unexpected error has been detected by Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6941084a, pid=1792, tid=3524 # # Java VM: Java HotSpot(TM) Client VM (11.3-b02 mixed mode windows-x86) # Problematic frame: # C [atioglxx.dll+0x41084a] # From which is coming this problem (also with 1.6, 1.7, 1.8) ? Thanks. [Note: this thread was started on sourceforge.net forums] |
Current timezone is GMT Sep 27, 2026, 8:56:50 AM |
