Print at Sep 25, 2026, 12:13:49 PM
Posted by kgingeri at Oct 29, 2018, 6:31:11 PM
sad   ARM Support on Chromebook?
Hi Emmanuel,
This is amazing software, so first off a big THANK-YOU!
I am trying to get SH3D working on a Samsung Plus Chromebook. It supports Linux and Android (so I have the Android app as well). This is a great machine as it has a garaged stylus and power enough.
However, it has an ARM (ARM8l, I believe - 64bit) processor so I'm stuck with ICEDTEA for jnlp support and I get errors trying to run the jnlp app. The ARM Java I can load (ver 8 from Oracle) has no JavaWS or Java3D support from what I can see. sad
Sooo... my question is, is it worth my time to try to download source and compile (I'm no Java pro) or will I still have Java3D or other lib support issues?
Is there anything else I can do to try to get this working on this machine?
I should mention that I can start it in 2D mode no problem - if I use the command line args "-Dcom.eteks.sweethome3d.no3D=true".
Karl :v)
