Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Problem with "Hole" Visibility while Import » » » » Post: Re: Problem with "Hole" Visibility while Import |
Print at Sep 26, 2026, 12:48:01 PM |
| Posted by kvepete at Oct 30, 2018, 2:16:58 PM |
Re: Problem with "Hole" Visibility while Import thank you for the reply, Export/Reimport was for example - when i construct a "special hole" with different objects, export it for use in the library. But the same problem is when i download this object: http://www.sweethome3d.com/models/roundDoorFrame.zip When i import it (door/window option checked) there is no cutout in the wall? Same with the "arc.zip" i've downloaded from this thread. http://www.sweethome3d.com/support/forum/viewthread_thread,3747#17527 See my screenshot Thank you. Kind Regards Pete |
Current timezone is GMT Sep 26, 2026, 12:48:01 PM |
