Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SweetHome3d shut down after some seconds » » » » Post: Re: SweetHome3d shut down after some seconds |
Print at Sep 29, 2026, 7:28:55 PM |
| Posted by C_Valanc at Jun 12, 2009, 10:41:00 AM |
Re: SweetHome3d shut down after some seconds I had the same problem after the version 1.4 (the first as I used), with 1.6 and 1.8 in the default directory. Same problem when I install the new version after I had uninstalled the previous version. Only the versions .jar was working. I has just to install the versions 1.5, 1.6, 1.7, 1.8 and 2.0 in different directories. * the versions 1.6, 1.7 and 1.8 run properly, in opposition to my previous tests (an old file not uninstalled ?). * in these same conditions, the version 2.0 starts and then stops after 2 or 3 s. |
Current timezone is GMT Sep 29, 2026, 7:28:55 PM |
