Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Web Start error message. » » » » Post: Re: Web Start error message. |
Print at Sep 30, 2026, 3:40:29 AM |
| Posted by pencilart at Aug 5, 2009, 4:51:00 PM |
Re: Web Start error message. Did you figure out the solution to your problem? Did you download the application? If so, you don't need the Java Web Start and you don't need to right click. If you have Java installed correctly on your system, the app should launch when you click on the executable file named, "SweetHome3D" (without quote marks. In the "File Type" section of your file viewer, it should say that it is a "Shell Script") |
Current timezone is GMT Sep 30, 2026, 3:40:29 AM |
