Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Smart modify all walls function » » » » Post: Smart modify all walls function |
Print at Sep 23, 2026, 4:20:35 PM |
| Posted by gcalavaro at Nov 18, 2018, 3:55:05 PM |
Smart modify all walls function I made a complex project with walls wide 30 cm. Now I need to modify with walls wide 20 cm. Yet, selecting and changing the wide property doesn't work as the wall is positioned at the center of the wide size (15 cm from each side) while I would like to move so that the external side of wall is the same as the old one. In other words, I need that the wall will also move 5 cm on one direction that toward the external side of the building. Is there a function that will automate such task? Thanks for your attention. Best regards, Giuseppe |
Current timezone is GMT Sep 23, 2026, 4:20:35 PM |
