Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: raising existing walls and ceiling » » » » Post: Re: raising existing walls and ceiling |
Print at Oct 13, 2026, 11:22:37 PM |
| Posted by VeroniQ at Dec 5, 2018, 7:26:05 PM |
Re: raising existing walls and ceiling Hello Bigjim. Select your whole design in Plan with Ctrl A (or cmd A on masOS), then Plan > Modify wall and change the height. Only your walls will be changed. If you have only one level, the ceiling will adjust itself at 290 cm. If you need a level, you can read this blog article . |
Current timezone is GMT Oct 13, 2026, 11:22:37 PM |
