Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem with interfering textures » » » » Post: Re: Problem with interfering textures |
Print at Oct 6, 2026, 11:37:57 PM |
| Posted by thoron at Dec 21, 2018, 2:58:15 PM |
Re: Problem with interfering textures Hello okh, thank you for this hint. But this was not the problem. Nevertheless you are right that two overlapping walls do exactly the same effect. I had this before and figured out myself this issue. In the case here, I checked this, but definitely just one wall. Unfortunately I can not post the sh3d-file, because I continued to work on this w/o having saved this situation. Oddly enough that the effect has gone away by continuing the work (see attached picture). If I see the problem again I will post the sh3d-file. ![]() |
Current timezone is GMT Oct 6, 2026, 11:37:57 PM |
