Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Combining the linked pool and the double garage...... » » » » Post: Re: Combining the linked pool and the double garage...... |
Print at Sep 26, 2026, 11:04:19 PM |
| Posted by Mike53 at Dec 23, 2018, 9:24:23 PM |
Re: Combining the linked pool and the double garage...... A few more images and the projects layout :- The Games room first. I couldn't find a reasonable baize for the pool table so i ended up trying grass, reduced to 5% of its original size, seems ok to me. A roof by Kerwin and 1 of Enkonyito's lamps are used over the pool table. A dozen walls, 3 rooms and 4 cylinders were used to make the enclosure for the dart board. The lamp illuminating the dart board is from the library, exported turned and imported, with a second original lamp, (body invisible) positioned to supply the light. ![]() Lounge /Diner I am posted these images whilst i have already decided to change the wall texture (yuk) And replace the dining table and chairs (poor mapping). ![]() The projects has basically 3 floor plus a sunken kitchen floor, but i have used 7 levels in total to create them. From the bottom up :- Games room, cinema and Gym are all below ground and therefore windowless, the floor of the indoor pool is also visible. ![]() The turntables in the garage. ![]() The 2 pools. ![]() The kitchen and the as yet unseen new indoor water feature. ![]() Ground floor has a breakfast area, a powder room and WC, Lounge/ diner, Utility room, main entrance and outside seating. ![]() Ist Floor comprises 5 bedrooms all with ensuite, most with walk in closets, 2 linen closets and a large balcony. ![]() Which just leaves the roofs. On this project i used all walls the create both roofs and ceilings. .Hope you like them. Mike |
Current timezone is GMT Sep 26, 2026, 11:04:19 PM |
