Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Color match........... » » » » Post: Re: Color match........... |
Print at Sep 30, 2026, 12:30:23 AM |
| Posted by Puybaret at Jan 4, 2019, 4:09:41 PM |
Re: Color match........... If you speak about color calibration on your screen, this is certainly not a task that can or even should do Sweet Home 3D. If you speak about how colors might look different in the 3D view and in SunFlow, I'm not sure it can be improved. Beside the fact that SunFlow may influence objects color because of light color (a white object under a blue light will be blue in SunFlow and white in the 3D view), the main difference between both rendering engines is that the 3D view also supports an ambiance color for objects (set with Ka line in MTL files). But apart in strange cases where this color would be set with a color that is not grey or equal to the main color, I don't think this is a problem. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 12:30:23 AM |
