Print at Sep 25, 2026, 11:03:57 PM
Posted by Matam at Jan 7, 2019, 11:04:34 AM
Re: How do I select a wall and delete it?
Hi, No the padlock is unlocked, thanks anyway.
But I'm pleased to find that It now works . I can't identify what I did was different, unfortunately.
For the benefit of the original poster and maybe others to follow, because it is tricky, I'll outline what I did.
Go to Plan and select 'Select' rather than 'Create walls'. (On Apple MacBook Air) Next Hold down Command key while selecting with the cursor the wall you want to delete. Next from Edit select Delete. That bit of wall should disappear. If you made the wall by a couple of attempts you'll probably have to delete it by a couple of attempts.
Cheers,
Matam
