Print at Sep 26, 2026, 5:41:13 PM
Posted by tarpon at Jan 12, 2019, 3:03:50 PM
Re: Levels questions
Hi Mike.
1. I can see that I didn't explain the situation well enough. All levels appear in the 3D window, my Level 4 "Second floor" sits, at what appears to be about 18", above the first floor levels. In the design window I can not see the first floor levels at all when I have Level 4 active and have only been able to position the "2nd floor" by using the positional measurements from the lower levels. "3d view" and select "display all levels".... didn't change the situation :-(
2. By merge I mean to condense multiple levels in to one single level... can that be done?
Any other thoughts? Is the program limited in number of levels per file?
Thanks again for the help,
Tarpon
