Print at Sep 30, 2026, 10:32:32 PM
Posted by hansmex at Jan 13, 2019, 11:13:31 AM
Re: Cut-out for kitchen sink
There are two ways to "slice through" an object:
1 - a door/window makes a cut-out in a wall
2 - a staircase makes a cutout in a floor/ceiling.
For your purpose the second option may be the best.
To do this:
1 - import a sink/drain and mark it as a staircase during the importation process
2 - make sure you have the AdvancedEdit plugin installed
3 - draw a room that has the exact measures for your worktop
4 - use AdvancedEdit's function Plan -> Edit Points to make any corrections needed for a perfect fit
5 - insert sink and drain
6 - select and use 3D View - Export to OBJ format - Selection only to export your model
7 - import your model and use it
